Discuss quick drying slc in the UK Tiling Forum area at TilersForums.com.
Andy Allen
1,318
Gloucester
there ripping the kitchen out on sunday and i got 2 days to tile the floor b4 the kitchen fitters come in, and where a wall was knocked out theres a bit of leveling to be done, i could proberly do it with the addy but if i could get a fast setting latex i could do it as soon as i got there and by the time i unloaded the van and set out the floor it would have been dry.
N
newlineuk
Uzin NC888
Extremely fine aggregate, therefore can be used as a
smoothing compound with a tight, sealed finish for a
”feather-edge” up to a max. thickness of 4 mm. Very rapid
setting and drying and, once set to accept foot traffic,
ready for covering after a further approx. 15 min on well
absorbent subfloors.*
Composition: special cements, mineral additives, polyvinyl
acetate copolymers and additives.​
3​
from a ”feather-edge” up to 4 mm thickness
3​
no primer required
3​
extremely rapid drying due the chemical conversion
of the mix water
3​
exellent surface finish extented
3​
fine aggregate
3​
bags are protected against damage
3​
plastic drum is available for mixing powder
3​
extended shelf life in original unopend drum
3​
profit yielding
ready for covering
after 15 min on
absorbent subfloors​
UZIN NC 888​
PRODUCT DATA SHEET​
Turbo skim and repair compound​
UZIN
N
newlineuk
X A45​
Rapid Drying and Hardening
Internal Repair Mortar​
MARCH 2010
PRODUCT DATA SHEET​
Features​
• Receives finishes after 1​
1/2 hours regardless of thickness
• Slump free - ideal for vertical and horizontal repairs
• Ideal for the rapid repair of internal concrete, screeds, renders
and concrete steps
• Other applications include forming ramps, falls and coves,
patching around fittings/pipework, and filling cracks and gaps
(43) Yq2
CI/SfB​
Reg No. FM 1207​
ARDEX UK LIMITED
Homefield Road, Haverhill, Suffolk CB9 8QP UK.
Telephone: +44 (0)1440 714939
Fax: +44 (0)1440 716640
Technical Services Fax: +44 (0)1440 716663
Email: [email protected]
ARDEX online: Tiling and Flooring products from ARDEX UK
Binds the mix water within the mortar, speeding drying and
hardening times irrespective of application thickness​
ARDURAPID
Reply to quick drying slc in the UK Tiling Forum area at TilersForums.com
Hi I asked the Wunda technical department if I can just use a Ditra mat only and not the SLC...
Good afternoon, Does anyone have experience of using grooved dry screed boards? (Bonus points...
TF Group Please Join
Andy Allen
Gloucester
quick drying slc
