Quote for removing garage foundations
Bunny,
I know labor rates vary and also costs of disposal, but for my area that sounds like a decent price (I converted pounds to dollars and sq m to sq yards), especially on the low end of what you quoted.
Site access would of course affect the final numbers.
Thanks for your replies. My decking is rotten and it is so much upkeep - around 40sqm in total and every year I have to paint it and it breaks when I walk on it. I guess I could replace the decking but that would be around 1k just for the decking alone :-(
bunny
is the concrete base causing the decking to rot? i built my old deck straight on to a concrete patio and never had any problems with it. my new deck is elevated but the deck posts supporting the main structure stand on their own concrete foundations.
if you can't replace the deck, why not just rip it out and use the concrete base as a patio instead?
GRR
were are you m8te as i still have all my contacts when i was a ground worker 3years diger driver i can get you a 1 half tone digger with a bracker cheep ill sort you a good price too get that up £**** two days work and ill sweep up 😛rrr: if you need the deck up ill sort you out drop me a line ill be happy to help you out no props that price is for the lot me and my m8te will drive up take it all up clean up and if needed relevel the site
paio block paving crazy paving tarmack brick work koi pond turf no probs bt rember if your going over the sub base then it must be a min 150mm below DPC
i cant stress that enuth i have lots of work soon for my uncle as he has damp tiles and plaster all blown as the path down the side is 320mm over the DPC not good i have dig out the path and drop it 800mm for a new path and then hack off tiles plaster render refloat&set all 4walls reskim and tile paint it new roof over the bathroom new render out side over 30m of bead not a happy bunny
any chance of some punctuation, ran out of breath reading it.
I have made a decision to go for impressed concrete printing. I have two quotes that have come out the same 2.5k ish for 40 sqm with 3 steps so I think that is a good deal.
Now I don't know how to choose them.
One said that he gets the concrete coloured rather than spray it after, the other's portfolio was great. Does anyone know anything about this industry?
