Discuss Raimondi Levelling System in the British & UK Tiling Forum area at TilersForums.com.
martin1c
633
Cheshire
I've used the raimondi system on large format tiles. All I seem to get is the 1m porcelanosa tiles these days and the Raimondi clips really help. Yes, it makes keeping the work area clean harder but on larger tiles it makes sure that they don't move. One point to note is that when using them on floor tiles they do try to move the grout gap when you tighten up the clip so I always knock the tile back into position. I've also found that this system is great when floors aren't quite level or have hollows in them. It's an expensive addition and I know that some will say that they don't need it because they can tile etc but I've found the Raimondi system very useful.
Spud
the lash clips wont level an uneven floor they just aid with reducing the lippage ,they are useful for some tiles and I did use them quite a lot a few months ago but have stopped now as I dont think they add in any way to the quality of my work and infact I noticed that on floors they can hinder you as they can create undulations and they dont allow you to clean your work as you fit it
RinkyDinky
I recently tried the ATR Tile leveller, the results were just fantastic, and i finished the floor in 25% less time than usual. Simple, cheap system but it definitely works. I have been tiling for many years and thought these were a gimmick but quite the opposite, I did try the LASH system but it was poor and the Raimondi was expensive and clumsy.
I now never go out now without a box. The website is informative, shows how many are needed and there are some neat you tube videos showing it being used. Hope that helps.
Reply to Raimondi Levelling System in the British & UK Tiling Forum area at TilersForums.com
Hi All, I urgently need some advice and not sure where to turn. We are having some major...
6K
Rookery
X
Hi I'm new on here and just had my floor tiled with 80x80 porcelin tiles. I knew it was a hard...
14K
L
11K
Rizzle from the Portizzle
clips and wedges improve your quality improve your rate of production?
8K
Hi All, I've just listed a full floor tiling set up of the Raimondi System on the Bay...
lizzardtong
L
    Votes: 14 9.4%
    Votes: 44 29.5%
    Votes: 17 11.4%
    Votes: 35 23.5%
    Votes: 21 14.1%
    Votes: 18 12.1%
    Votes: 16 10.7%
