Discuss Raimondi Pedalo ? in the Australia Tiling Forum area at TilersForums.com.
ruairi mac
I've had one for about 5 years now. Great bit of kit on the right job. I tend to only use it on floors 40m or more. It takes around 3 yellow builders buckets to fill it with water and although it has wheels, it's a two man lift to get it back outside to empty it. I would recommend getting the sponge with the one solid pole. I had the one that joins in the middle but I found it to be a weak point when leaning down on the pole to wash and it's not easily dismantled if you were thinking of saving space.
Hope this helps.
judge
1,078
Same as above.you can't lift it over door thresholds on your own so you need to work out where you your going to empty it before you fill it.I tend to use the washboy for the first washdown as the pedalo doesn't quite rinse enough of the water out the sponge but it definitely saves the oLe back on the larger floors
widler
1,328
England
It is heavy when full, but us young lads should be strong enough to lift it ;)
As for the cleaning , I find it cleans really good ,without leaving much residue on the tile, like I said above I don't have the posh one ,but I squeeze it out under the rollers,and it works a treat :)
Reply to Raimondi Pedalo ? in the Australia Tiling Forum area at TilersForums.com
Hello, after tiling the kitchen area I did grouting but I am not happy with the results. The...
Raimondi Pedalo ?
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
