Discuss Random floor pattern for wood effect floor tile in the Canada Tile Advice area at TilersForums.com.
How would you suggest "randomising" a 90 x 15 plank wood effect tile running through a kitchen / dinner into a entrance hallway?
Standard should dictate no more than 33% offset to adjacent tile, and I don't want to end up with the "perfect grout lines" of a tell-tale tile floor? Would you start with some random off cuts (all less then a third off the length) and just work off your start line with that, and carry it through?
Floor will be as level as can be with new self level latex being spread.
Also expansion joint? would they be required? It's technically 2 rooms covering about 42m2.
Recommendations on an adhesive & grout? 9mm porcelain tile, 3mm grout gap.
Ttt1601
If you use clips you can go more than the 33 % overlap, and still have a perfect floor, then just stuck em down where they fall is what I do, any off cut gets used to start a new row at some point, or I'll just put one down in front of me where I am, just keep and eye out that you don't wnd up accodentally doing a row exactly the same
Thanks for the advice. The kitchen / dinner is 1 room, doorway out to the hallway.
Floor is being latex leveled in 1 run all the way through both areas, so should be very level.
I was going to use lash clips anyway although I do sometimes find them hard to push under the tile once I have applied pressure and slid the tile into place???
The tile is a bayker porcelain 90 x 15, so taking that information into account would you guy / girls go random pattern over 33%? Or to be safe would you stick to 33% and under?
I was going to use bal single part flex, and micromax2 grout? Or would a wide joint grout be just as good (and cheaper). Would admix be worth putting in?
To be honest, ALL the information you need is in the posts above.
3mm is not a wide joint.
But it is your choice what grout you use.
Additive, Why?
It's a solid floor isn't it?
Bal spf is a good adhesive.
Reply to Random floor pattern for wood effect floor tile in the Canada Tile Advice area at TilersForums.com
Hi all, We employed a tiler to lay some rectified wood effect planks in a herringbone pattern…...
Hi, 1200 wide tray and tiling shower enclosure recess with metro tiles where the 1200 wide...
gamer1
    Votes: 5 5.0%
    Votes: 8 8.0%
    Votes: 6 6.0%
    Votes: 25 25.0%
    Votes: 14 14.0%
    Votes: 27 27.0%
    Votes: 3 3.0%
    Votes: 2 2.0%
    Votes: 19 19.0%
    Votes: 18 18.0%
    Votes: 10 10.0%
    Votes: 5 5.0%
    Votes: 3 3.0%
    Votes: 1 1.0%
