Rapid set - TOO RAPID SETTING!!
thegwads
hi all
doing a little floor today, bathroom upstairs, boarded out and screwed corrctly etc... anyhow using granfix 1 part flexi rapid set which i just used on a 55sq. meter floor no problems - although that house was cold so took a decent amount of time to go off.
any way, today first mix went off in about 15 minutes, 2nd mix which i did on the wet side took about 20 minutes to go off. using clean buckets, clean water etc...
turning out to be a ball ache on 5sq. meters with bath, loo, sink in the way.
can anyone suggest an adhesive, flexi, which doesn't set so quickly. need to be grouting same day, so need rapid set, but could do with a slightly better pot life!!
any suggestions
basically i will probably dry lay all of it tomorrow, cuts etc, then just mix up small amounts at a time, but really winding me up now!!!
cheers
how do m8, i done a small floor today, i used bal rapidset flex, i was getting between 20-30mins so wasnt 2 bad cos had drylaid it first, £26.67 for 20kg from CTD, hope this helps if not just take no notice:lol:
hi all
any suggestions
cheers
Have a look at Ardex 7001, specially designed for board floors. has a pot like of 30mins, mixed very thin to get 100% coverage, can grout in 2 hours. About £27 a bag though.
Grumpy
quite a few manufactures have been having a problem with flash setting over the last couple of years they tell me its to do with the European regs had to change the cement not sure i believe them but tell them because if you don't they wont know a few of the companies have slowed it down to 3 hours because of the problem 😛ete ps i have seen some go off in less than 5 mins :lol:
funny you should mention new regs - the granfix i got today was in a new bag to the last batch i used, literally finished big floor 10 days ago, picked up bag today and totally different bag although the tile shop assured me it was the same stuff, but damned if i believe them - this stuff went off so quickly!! 2nd mix actually went off from perfect consitency to unable to trowel it at all in about 10 mins!!!
i am not the quickest man around, but finding it very tricky with this rapid set - convinced it is made with different stuff!!
even dry laying all but the intricate (wet) cuts, i am guessing 3 or 4 small mixes is the only way i'll be able to do it!
wishing i'd used dunlop ready mixed stuff now and told the customer they gotta stay out the room for 2 days - but just not feasable. probably gonna be a bag or 2 out of pocket now due to wastage!!
please don't forget to phone them and let them know that tilers have been talking about the problem on this tile forum or they wont know and therefore all those poor guys and girls out there going mad and losing money
:furious3: :mad2:
pjc - that was me posting last one, logged out for some reason!!
so - you have the same problem then?
in hindsight, even allowing for atmospheric conditions, the first granfix batch took easily 45mins, if not longer to go off on the really big floor i did.
the new batch, in a different bag etc... definitely took less that 20 mins to go off. the house was not that much warmer, although the room was a lot smaller when it went off quickly, which may have something to do with it, but how can 20mins be acceptable - especially in a cramped bathroom!!
must have got fewer than 5 tiles down on one mix!
Hi mate. May be you´ll have more fun using an adhesive for marble, check it´s times. Example: I manufacture the Nordas Marmorflex (available in Germany only), my marble and granite customers wanted it not to fast as they can´t tile big areas then, so I make it with a pot time of ~ 1 hour and a setting time of ~ 6 hours before grouting. That is how they wanted it and I think in the UK adhesive dealers can provide something else like that. Martin
good news for the customer if he is a guy,er excuse me m8 but you will have to go to the pub for a pee or a number2 because you cant walk on your floor for 2 days.
PCI-FLEXI RAPID SETgreat stuff no problems at all with this ever.:thumbsup:
hi all
any suggestions
cheers
If you're adhesive is going off while it's in the bucket never add more water and mix it again, throw it away and clean the bucket a bit and make a new mix as and when you're ready.
Also, be sure to prime when you need to.
no i am not - £51 a bag without account, £35 with account - then manager not particularly responsive to my "this is a joke surely?"
will probably dry lay and mini mix then
i think lots of places are quite happy to charge you well over SRP if you are willing to pay for it try your small local tile shop you may find you will get a lot better deal
I think it can maybe be a false ecomomy to use rapid set sometimes to try and
get a job grouted in the same day, because you probally wont save time that way anyway because of all the mixups that have to be done, and it just makes it hard work.
I've used a make called ULTRA for floors.
Got it trade price cost about £10 before vat per bag.
Have mixed a bucket full at a time and usuable for about 2 hours at least.
thegwads,
Perry,
thegwads,
Perry,
