Discuss Re: advise required... in the British & UK Tiling Forum area at TilersForums.com.
cappsie
Hi Guys
This summer I'm considering doing some damp work myself, I don't believe it to be that difficult - i.e. stripping plaster and drillling and injecting bricks, then fixing the plastic membrane to the wall. The replastering, however, is tricky as I've never done it before. Then again, I'd never attempted tiling before.
Any advice :)
White Room
Hi Guys
Ok this might need to be moved to a new thread.
Any advice :)
Try dryzone at www.safeguardeurope.com, What is the plastic membrane your talking about.
White Room
Hi Cappsie, remove plaster to a height of 1m, drill bricks, 2 holes per brick (not into the mortar) inject chemicals then render with sand and cement, do not use backing plaster, then skim the s&c..use a salt retardent in the render mix
hope this helps..Mark.
What is a salt retardent, If you use soft sand the chances are you may get problem's, use a good rendering sand with integral waterproofer or renderlite from soverign made for the purpose for damp injection.
Reply to Re: advise required... in the British & UK Tiling Forum area at TilersForums.com
Trying to Get bathroom re tiled, had conflicting advice from a few tilers, I’m a total novice...
6K
Hello all, I seem to be in a dilemma with the tiler and tiling my bathroom. First of all...
17K
I had a job booked to retile 19m of kitchen floor where the house had apperently had a little...
wayfoward
    Votes: 9 5.3%
    Votes: 17 10.1%
    Votes: 12 7.1%
    Votes: 48 28.4%
    Votes: 21 12.4%
    Votes: 40 23.7%
    Votes: 4 2.4%
    Votes: 4 2.4%
    Votes: 23 13.6%
    Votes: 19 11.2%
    Votes: 17 10.1%
    Votes: 8 4.7%
    Votes: 5 3.0%
