DHTiling
You can get 10kg bags..🙂
Ian, sounds like you know your onions, does powder mixed adhesive spread more easily than ready mixed?Just to add another point, if you are on a budget you will get better value from a bagged powdered adhesive. A 20kg bag will cover around 8m2 per bag and a 15 litre tub of ready mixed will cover around 5m2 for a similar price. (based on using a 6mm notched trowel)
I stuck some tiles down with bnq ready mix flexi for wood floors about the same time the chap made this post and they are still stuck down today .Ian, sounds like you know your onions, does powder mixed adhesive spread more easily than ready mixed?
ta!! one other Q is it best to adhesive the tiles one day grout the next or spread it out for an entire day
Hi, have you ever used powder mixed adhesive?I stuck some tiles down with bnq ready mix flexi for wood floors about the same time the chap made this post and they are still stuck down today .
Yes all the time , not used ready mix since was for wood floors , imho ready mix would use only for light weight ceramic tilesHi, have you ever used powder mixed adhesive?
No , not in my experience powder mix is heavier going , but that would not be a reason to use ready mix , the ready mix i used for the floor that time was very lightweight and easy to spreadDoes powder mix adhesive spread easier than ready mixed?
