Discuss really big tiles in the Canada Tile Advice area at TilersForums.com.
Spud
its starting to get silly how big tiles are now 1800 x 900
Spud
cut the short side 900 on a push tile cutter long cuts are being done with a 4 1/2 inch grinder with a porcelain blade they cut really well fixing them with tile master setaflex over ditra and using my vibration compaction plate (tile iron) going to mitre all the external corners should be nice when finished,sorry about the cloudy images the lens on my camera phone has had it
charlie1
whats your troweling size and setting method for those gary? Id imagine the floor has to be pretty spot on flat -3mm / 1.8m?
Spud
levelled the floor at the prep stage in order to bring it up to the same finished floor height as the adjoining wood floor it was near perfect to a 2m straight edge ,then ditra matting then tiles the floor was trowelled with a 12mm square notch and the tiles were back spread flat then trowelled with the same 12mm trowel these were then fitted and vibrated with a hand compaction plate
jonnyc
I thought I had seen alot but this is new and exciting territory and you are leading the field of fixers who will follow.
I have a very vivid memory of quoting to do a big stone job for boss of French connection about 4-5 years ago and a very small part of my package which was primarily stone included this porcel thin product. I made extensive enquiries with adhesive manufacturers and opted out of the the porcelain tiles and subsequently lost a very good project.
It's never too late to learn a new skill as we all know , and I see this development as just another progression in the tilers never ending adaptation to new products on market
personally I would be quite happy to carry on in the little speciality works that I offer
But if that dies off then I will be there like we all have to be .
Reply to really big tiles in the Canada Tile Advice area at TilersForums.com
  • Poll
I'm searching for 42 pieces of 12" x 12" Verde Alpi marble tiles. Preferably honed. 12" x 24"...
I've been desperately looking for the 3" x 12" bullnose tile that matches this. It's called...
Hi I've been tiling for a few years now, I don't really do large format tiles but I've turned...
Hello, First post. Wish I had known about this forum several years ago. Here's my question...
really big tiles
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
