janzbro
hi everyone, is it possible to reduce the diameter of the soil pipe from the toilet to the stack.
Just found out the house has an internal stack and the toilet waste goes through the wall into the airing cupboard and then drops down stairs.
This is leaving me with limited space across the back wall to fit a 1200 x 900 shower tray and fit a stud wall boxing in the soil pipe and the shower hot/cold supplies as I only have 1325mm wall to wall.
I could put a stud under the soil pipe and build a stud frame above it then board the wall, this would leave the p/board touching the soil pipe but Im worried about movement of that upper frame.
Any ideas on framing out or reducing the soil pipe would be much appreciated.
