Removing Artex.....
I removed all the artex from my 30s semi.
DONT use a wallpaper stripper, it makes a total mess.
Some pre 1980s Artex contains very small amounts of "heavy" asbestos, you can see it as small silvery specs in the dust. I have read that the levels of asbestos are not going to kill or do anywhere near as much damage as insulation / roofing / blue etc, and as it's heavy dust it can be vac'd up with a HEPA vac or dyson. (Disclaimer: I believed this and I may die from it in 20-30 years time so don't believe everything you read!)
Most of the artex I removed came off the underlying lining paper or plaster really easily using a jumbo scraper which you can get for about £6 - long handle with a big h/d razor blade on the end - works a treat!
For really tough areas including some of my ceilings I hired one of these babies:
[DLMURL="http://www.hss.com/g/5231/Drywall-Sander-Kit.html"]HSS Hire › Drywall Sanding Kit[/DLMURL]
If you go down the messy route make sure there are no kids or pets in the house. Wear a good mask FFP3 minimum and goggles. The dust gets everywhere so seal rooms and wear paper overalls.
This was before I learnt to plaster. Now I just scrape off the bumps with a clean trowel edge, couple of pva coats and skim away - easier and cleaner.
as a plasterer..i'd say give it a good soaking and start scraping..wallpaper steamers as all ready mentioned work well. As dh says if painting knock off the highspots and re-skim, if tiling i'd scrape on a day rate...I wouldn't be confident of re-skimming and then tiling..although it does stick like the preverbial to a blanket..Mark.
Thanks for the help guys.
The guys said he would take it off himself as he has done it before and doesn't mind. (why not say that in the first place?)
Anyway I gave them a price for just tiling 7m2 in ceramics for £150 including adhesive and grout etc.
Not heard back yet so doesn't look like i'll be doing the job anyway! Not sure what price they were expecting.........
Gaz
Removing Artex.....
GazLC81,
GazLC81,
GazLC81,
GazLC81,
