Discuss Removing dry grout from porcelain tile surface in the British & UK Tiling Forum area at TilersForums.com.
Polishtradesman
If it is cement based grout (CG2) i alweys use wire-wool ( i have used that thing to clean copper pipe before soldering), it is best thing to remove grout without use chemical substance ( you need alweys do trial before use, sometimes it leaves ping colour on tiles). If chemicals you can use phosphore acid based products already made for removing grout like Broken Link Removed
Reply to Removing dry grout from porcelain tile surface in the British & UK Tiling Forum area at TilersForums.com
Hi, I wonder if anyone knows what the thin web-like coating on Harmony Nador tiles is made of...
    Votes: 9 5.6%
    Votes: 17 10.5%
    Votes: 11 6.8%
    Votes: 45 27.8%
    Votes: 21 13.0%
    Votes: 38 23.5%
    Votes: 4 2.5%
    Votes: 3 1.9%
    Votes: 22 13.6%
    Votes: 19 11.7%
    Votes: 17 10.5%
    Votes: 8 4.9%
    Votes: 5 3.1%
