I just bought a house and noticed the stone resin shower tray is leaking.
The Silicon job is pretty crap so I started removing it with the aim of redoing it properly but noticed the shower tray is still wrapped in plastic around the edges meaning the Silicon hasn't bonded to the side of the tray but to the plastic. No wonder it's leaking as the water can just flow between the tray and the plastic.
Now I'm never gonna be able to remove all this Silicon and plastic as the gap is tight and I can't get any tools in there. I'm going to get some Silicon remover and give that a go.
I've also ordered a set of these trims:
How critical is it that I remove all the existing Silicon? I assume as long as I get a decent seal between the top side of the tray and the tiled wall with the trim then the seal between the edge of the tray and the wall will be less critical.
Any advice?
Cheers
ShowerSeal Ultra 10 Half Seal - 2 Sides | Byretech Ltd
ShowerSeal Ultra 10 Half Seal - 2 Sides available from Byretech Ltd a Bathroom water damage prevention specialist store
www.byretech.com
Any advice?
Cheers
