Resin topped porcelain
sounds like double loaded porcelain 4 mm layer or quailty porcelain on top with cheaper clinker
porcelain on bottom .the top coat resin ones you dont seal as it can eat the resin and its all ready sealed by its
nature .picture would help .
You are bang on Ray. It's layered porcelain. Just found out that from supplier. Looks like resin because of the small holes in the top layer to mimic stone. Pencil marks aren't easy to get off at the moment and I'm pretty sure the kf stain stop isn't the right sealant for this stuff. Ltp say mattstone, what do you lot say?
when it comes to sealing get the supplier to spec that for you then its on there shoulders not yours .
there have been big problems cutting this type of tile .and thats what you need to check out how well they
cut . you may find yourself cutting every one on a wet saw .a lot will depend on the quality of the base layer
if you can see little black specs in base layer you may have a hard time and need a lot more wastage .
I asked the supplier about sealant and they said it didn't need it. I pretty sure they do as a pencil mark is really difficult to get off.
They,suprisingly, cut really well on a tx and very cleanly with a grinder too.
Really concerned about the sealant though as they're in shower cubicles.
With you guys on ,ask the supplier, even if this was impregnated,mpencil marks can still get into the micro pores of any tile and can be difficult to remove.
If in doubt , stain test an off cut ,half impregnated , would also check a grout release if unsure.
They've said no need to seal. What would you recommend I test with Bob?
Cheers
Did a test with mattstone and looking good. Cheers folks!
    Votes: 9 5.2%
    Votes: 17 9.9%
    Votes: 12 7.0%
    Votes: 49 28.5%
    Votes: 21 12.2%
    Votes: 40 23.3%
    Votes: 4 2.3%
    Votes: 5 2.9%
    Votes: 24 14.0%
    Votes: 19 11.0%
    Votes: 17 9.9%
    Votes: 8 4.7%
    Votes: 5 2.9%
