E
Eddm87
Hi.
Just wanted to make sure I’m doing this right...
I have moisture resistant plasterboard dot and dabbed on walls. Floors have tile backer board down. Walls to be tiled top to bottom, floor tiles too. All tiles are 600x300.
I am looking at getting the adhesive and primer.
Was going to prime the walls only with primer G. Without scoring.
Was going to get Adesilex p9 for walls, but don’t think I can use this for the floor as not flexible enough?
Originally I was going to use Mapei rapid set as it was flex and had cement properties but the spec says can’t use on plasterboard.
So how does all that sound? I know there’s a thousand ways to do this but knowing me, I will still muck it up!!
Edd
Edd
