Ripping up a floor dilemma
MikeW
Some of you may remember I recently put up a request to identify some tiles that are on my kitchen floor (the now discontinued Dorset Wooliscroft Multiversatile) as I wanted some to finish the job that wasn't properly completed by a previous owner.
After realising the chances are very slim that I will actually find any amount of these tiles I have now resigned to the fact that I will need to rip the floor up and start again with something different.
The trouble is, as an amateur DIYer this isn't something I have any experience in.
My father in law reckons that ripping them up is the last thing I want to do as he says it will take weeks of chiseling to get the concrete beneath clean of all the tiles and hardened adhesive and into a position where I could stand any chance of laying any new ones.
Is he right or is he being a bit over the top with his prediction? I don't doubt him but I'm not entirely sure he is speaking from experience, more making an educated guess and/or trying to save me some aggro bless him!
Any advice from those who are experienced however would be very welcome!
All the best
Mike
You need to get an SDS drill with a chisel bit. Then latex the floor once its all up.
Have you thought of employing a tiler for the job?
Hi. No I couldn't afford to. I'd do it all myself. If it is possible to get the concrete back to a workable state I won't need to. It's just a question of how difficult and time consuming it's going to be?
Cheers
It's not usually that messy on floors. SDS as said. Then I used to use a house brick to rub over the floor, that part is a bit dusty. Gets the rough bits off. Then latex it.
Cheers
The tiles should come up fairly easy Its the adhesive that will be a pain...do-able but very time consuming hence why I just latex over it..
It's a product commonly know as SLC (self levelling compound)
It's a cement based product mixed with water, usually with added fibres, that can be used to level a floor.
This will flatten your adhesive covered floor ready for tiling as long as the extra height isn't an issue.
There are a fair few to choose from, it'll depend on your area what's available.
Tilemaster & Weber are the two most commonly used SLC's by guys on the forum it seems.
Oh right, yes I know what SLC is. Didn't realise it contained latex hence why I didn't have a clue... I doubt I'll have much height to play with so probably won't be able to go down that route.
Once u've tackled a bit of the floor and you know what you're dealing with, u can make an informed decision then.
Good luck!
It might be worth mentioning that the part of the floor which wasn't tiled was the bit round the outside where the old kitchen/sink units sat. Obviously this wasn't strictly "not completed" as I put it but done deliberately to save money as that part of the floor wouldn't be seen which is perfectly understandable.
My problem is that I am doing away with normal kitchen units in favour of stainless and/or wooden work benches which is partly a matter of style but also as the kitchen is intended partly for commercial catering use, a practical one as well.
Bearing in mind the bare bits of floor would be quite visible under the benches, what would be the option for laying something else there and leaving the main floor as it is? Could I use a different tile or would that look daft? Or what about a different materiel altogether? (I'm open to any suggestion here with the exception of laminate flooring!!)
The more I think about it the more I'd like to avoid ripping up the old floor plus the time/stress/expense of laying a new one.
Sorry to throw another spanner in the works just as you thought the thread had been wrapped up! :grimacing:
A couple more questions to follow...:flushed:
Mike
You could use some tiles which are lookalikes and the same size , but only you know what's going to be pleasing to the eye Mike, of coarse you will have to take the cut tiles up to put full ones back in where they have cut around the units .
But like I said, you could get some tiles but it's your decision what will look ok 🙂
Why don't you take a couple of pictures of the whole space involved, add to that a diagram of your new kitchen layout and upload it here. Who knows some of the budding designer types here may see a solution you can't at the moment. Fresh eyes and all that! 🙂
The trouble is I can't seem to find any lookalikes. The size 195mm x 95mm seems to be quite unusual for a tile based on the google searches I've done so may be difficult to find a size that can be tied in with the existing and look half decent.
At the moment the kitchen units are still in situ so you wouldn't benefit from the photos but it's definitely a good idea and will probably do it once I'm at that stage. There are 101 other jobs to do in the meantime but I'm thinking well ahead with the floor as I know it will become a major snag if I'm not ready by the time I'm ready to get moving on it.
Note that for kitchens to be used commercially they need to use epoxy grout on walls and floors. Because bacteria can't settle in it. Tile choice becomes limited too usually.
I suppose it depends on what it's actually being used for to class it as commercial use but worth checking maybe.
I spoke to the local EHO a while ago and he said the requirements for home commercial kitchens are a bit more relaxed than say if it was a restaurant or pub so I doubt they would be that bothered but I will by all means look into it. Thanks
If you're selling a product to the public, you need to comply with food standards. Just the same as a 5 star restraunte.
And if the council get a phone call to ask what your food standards rating is, they will inspect and give it one.
A lady got clocked not long ago for selling battery chicken eggs as free range via a honest box. The food never even entered the kitchen but her kitchen got inspected.
Sounds a bit extreme regarding the egg lady. I think by all accounts different local authorities have different views. I'd heard things like, you can't have a washing machine in a commercial kitchen...You must have two sinks, one for food prep, one for hand washing...You must have seperate fridges. One for catering, one for your own use...
When I asked the EHO, his opinion was that they understood that such demands were a bit unreasonable for small, occasional home caterers and so long as cleanliness was up to scratch and records i.e. fridge temperatures etc being kept they would be happy. Those were his words but I will certainly double check regarding grout and tiles.
No worries that would make sense. They have to have some leniency surely.
Cake bakers and whatnot must adhere to such standards.
Yes my missus is a cake maker. Looking to do one or two local events and take private orders etc. 🙂 :shortcake:
I see I seeeee
Not sure if it'll be as strict then as to need epoxy. But for the sake of easy cleaning I'd stick to ceramics. Nothing porous.
MikeW,
Dan,
MikeW,
Dan,
