Tiling Tool Suppliers
Discuss Rubi cutter problem??? in the Tile Cutters (Manual & Wet Cutters) area at TilersForums.com.
Jimmy
I found a neopreen(?) mouse mat inbetween the breaker and the tile helped lots and a firm scribe even a double scribe for thin strips . Had no broken tiles over 80 sqm of 600x600 polished black B&Qers , but you get gentle crack with a firm controled pull of the breaker . Took the job over from 2 tilers using a wet bridge saw the customer was well impressed:thumbsup:
Which cutter? did you use
theanalyst
This is the Ts 60 PLus, not sure if thats the same as the one you are on about.
but I have never had any problems with it myself...with ,as I said 600mm x 30mm x 15mm polished porcelain down to cheapo ceramic.
its all in the wrist action as they say :thumbsup:
Just seen my typo here. i did of course mean
600mm x 300mm x 15mm ... :smilewinkgrin:
Reply to Rubi cutter problem??? in the Tile Cutters (Manual & Wet Cutters) area at TilersForums.com
Hi everyone, I'm not a regular tiler, just someone who is trying to fix up a few rooms around...
Sigma or Rubi Tile Cutter? What is you experience with either, or even lucky enough to have both...
Paul Smith
1200mm Manual Tile Cutter for around £100 Topway Tile Cutter 1200mm / 1000mm - Porcelain...
Admin1
I need a tile cutter gor 600x600 Italian porcelain and am close to pulling the trigger on the...
Popular Tile Cutter Threads
    Votes: 9 5.4%
    Votes: 17 10.2%
    Votes: 12 7.2%
    Votes: 47 28.3%
    Votes: 21 12.7%
    Votes: 39 23.5%
    Votes: 4 2.4%
    Votes: 4 2.4%
    Votes: 22 13.3%
    Votes: 19 11.4%
    Votes: 17 10.2%
    Votes: 8 4.8%
    Votes: 5 3.0%
