For Sale
Rubi DW- 200-N Bridge Saw 240 V
I bought this off Dave at Trade tiler about 4 / 5 years ago as I had a thick travertine job to do and have used it occasionally since then but not much Its still got the original blade in it and that still cuts fine. I did notice it was cutting slightly off square last time I used it so the squaring arm might need squaring up as its not had a lot of use so I presume that's the reason. Welcome to come and have a try if you want.The folding legs and the wheels make it an easy one man set up job.Also still got the two blades for it that I have never used
official spec
Rubi DW-200-N
official spec
Rubi DW-200-N
- Detachable table to facilitate the cleaning of the machine.
- Includes wheels and a handle to ease the movement of the machine and its loading on to a vehicle.
- System of fold away legs.
- New guide with an easily adjustable ruler.
- Motor assembly mounted on fold-away sliding bearings for mitre cuts.
- Vertically adjustable mobile head with plunge cut.
- Complete with 8in / 200mm diamond blade.
- Single phase motor 1.5 hp/kw.
- Cutting height 32mm / 1 5/8in.
- Cutting length 750mm / 29in.
- Wall chaser effect cutting.
- 2875 rpm.
Direct drive. - 1.5m (4.9ft) electric cable.
- Reinforced chassis for structural rigidity.
