Gazzer
Below are some useful hints/tips for getting the best results from your RUBI Bridge Saw
- Always make sure the water level is right to the top of the water tray as this will make the machine stable.
- Make sure the machine is on level ground as this can make the machine cut off line if the chassis is twisted.
- Regularly remove the excess off cuts that fall in to the water tray as this will reduce water volume and create sludge.
- Check the water pump and lines are cleaned regularly by putting the pump in a gallon of clean water and allow the water to run through the pump.
- Always use the right blade on the right material. It is not one blade doe's all.
