Discuss Rubi ND180 BL electric is it overkill for a DIY'er in the British & UK Tiling Forum area at TilersForums.com.
Jammy
Hi All,
I've got a 30 metre squared porcelain tile job to do (two sizes :- 600 x 300 and 400 X 400). From memory, I think the tiles are 8mm thick could be less. I read the excellent review of the Rubi ND180 wet cutter on the thread in this forum.
The question is should I go for the Rubi cutter at £132 ish plus £57 for the CPC2 diamond disc, or is this overkill for a one off DIY job. Or should I go for a generic cheaper £50 wet cutter and no CPC2 blade.
Thanks in advance :thumbsup:
Alan.P
Hi Jammy.
If it is a one off, there are 2 or 3 ways of looking at it, buy the better cutter and sell on after use, buy the cheaper cutter and keep in case of, or hire a cutter for the .... erm, wet cuts, are you planning on doing all cuts, wet and dry on the wet cutter or have you got a dry cutter ? It's just time, disc life, if these are not big factors then go for a cheaper disc or 2.
Hope that makes sense :thumbsup:
Jammy
Thanks Alan, that does make sense.
I've purchased a Rubi Star N 60 plus tile cutter for the dry cuts. I'm thinking I'll need a wet cutter for the "akward" cuts. My previous tiling experience was a large-ish kitchen floor but those were smaller 300 x 300 ceramic tiles. I've not tried cutting (wet or dry) these larger 600 x 300 porcelain tiles yet. Are porcelain ones much more difficult ? I hope not.
Think I'll contact my local hire shop and see what's on offer there.
Cheers Jammy :thumbsup:
Alan.P
Hi Jammy. The porcelain tiles are obviously harder than ceramic but will cut easily enough, 10mm wheel and a firm score, and a quick ish breaking action. I can't say anything about the Rubi you have because I've never used it, someone else may pass comment. If you haven't got many wet cuts to do then maybe a 110mm angle grinder with a turbo blade instead of a wet cutter might do you, cheap enough and always handy to have :thumbsup:
Reply to Rubi ND180 BL electric is it overkill for a DIY'er in the British & UK Tiling Forum area at TilersForums.com
E
Apologies if this is done to death already, but I've had a search and cant find anything...
GoneGuy
H
Hi everyone I've had some tiles for a good 9 months lying around waiting to be put up by my...
5K
Qwerty
Q
V
Evening guys recently got my own place, and really want to sort out the kitchen. I thought my...
Veitchy
V
Hello fellow Tilers, I am in need of assistance as I am doing a 26m slate floor job, the...
7K
p4ulo
Not a question, but a suprising observation of an illusion! My next task has been to come up...
bcd-87
    Votes: 9 5.8%
    Votes: 15 9.6%
    Votes: 11 7.1%
    Votes: 46 29.5%
    Votes: 19 12.2%
    Votes: 37 23.7%
    Votes: 4 2.6%
    Votes: 21 13.5%
    Votes: 18 11.5%
    Votes: 17 10.9%
    Votes: 7 4.5%
    Votes: 3 1.9%
    Votes: 4 2.6%
