Guest viewing is limited
Tiling Tool Suppliers
Discuss Rubi Tile cutters... in the Tile Cutters (Manual & Wet Cutters) area at TilersForums.com.
Rich
Designed to suit the needs of professionals all over the world, Rubi cutters are fitted with a multiple point or single point breaking system with powerful breaking strength at any angle, highly accurate measuring systems, carrying case, and a wide range of accessories for all types of cutting and finishing on any type of tile.
TS
images
  • TS-40 PLUS, TS-50 PLUS, TS-50L PLUS, TS-60 PLUS and TS-70 PLUS available.
  • High performance single point breaker
  • Chromed and rectified steel guides with anti-corrosion treatment
  • Lateral stop for straight and 45 degree repetitive cutting
  • Ergonomic shape and reinforced base
  • Supplied with case and complete set of tools (6mm and 10mm)
  • Direct vision of the scoring and cutting line
  • Suitable for 6mm to 22mm scoring wheels
  • Adaptable accessories: Adjustable square, manual drill, maintenance kit and portable tool box
  • 15mm max cutting height (max tile thickness)
  • 400kg separator/breaking power
  • Fixed separatorrepetitive
  • e cutting guide
  • 45 degree cutting
  • TS-30, TS-40, TS-50 TS-50L and TS-60Availablee.
  • TS-PLUS
  • images
  • High performance single-point breaker
  • Special mounting for breaking system lever
  • supplied with casandbd complete set of tools (6mm and 10mm)
  • New exclusive design
  • Suitable for 6mm to 22mm adaptable aninterchangeablele scoring wheels
  • Adaptable accessories: Adjustable square, manual drillmaintenancece kit, portable tool box
  • 15mm cutting height (max tile thickness)
  • 750kseparatoror/breaking power
  • Fixeseparatoror
  • 45 degree cutting
  • High performance moving breking system
  • chromed and rectified steel guides with anti-corrosion treatment
  • Lateral stop for straight and 45 degrees repetitive cutting
  • Plywood base with phenolic water protection
  • Base accessory for large format
  • With scoring 8mm scoring wheel
  • Adaptable accessoriesManualal drill and maintenance kit
  • 400kseparatoror/breaking power
  • fixeseparatoror
  • 45 degree cutting
  • base accessories
  • TF
  • images
  • TF-40 and TF-availableble.
  • TF PLUS
  • Double rectified steel guides with anti-corrosion treatment
  • New reinforced lateral stop for great precision for making repetitive cuts at 0 degrees and 45 degrees
  • Plywood base with phenolic warepellentlent protection
  • accessory base for large format tiles
  • 8mm scoring wheel included
  • Direct vision of the scoring and cutting lines
  • Adaptable accessories: Manual drill and maintenance kit
  • 40separatorator/breaking power
  • Fiseparatorator
  • 45 degree cutting
  • Base accessories
  • TM
  • images
  • High performacesingle-point breaker, adjustable from 6mm to 21mm
  • Chromed and rectified steel guides with anti corrosion treatment
  • Lateral stop for straight and 45 degree repeated cutting
  • Base accessory for large format tiles
  • Supplied with case and complete set of tools (10mm and 18mm)
  • New greater resistance transport case
  • Adaptable accessories: manual drill and maintenance kit
  • 21mm cutting height (max tile thickness)
  • 10separatorrator/breaking power
  • 45 degree cutting
  • Base accessories
  • TM-70 and Tavailableiable
TR
images
  • High performance moving breaking system
  • Lateral stop for straight and 45 degree cutting
  • supplied with case and complete set of tools (6mm and 10mm)
  • Angular measuring system for 0 to 45 degree cutting
  • Adapaccessoriessories: Manual drill, Glass mseparatororator, Maintenance kit and portable tool box
  • separatororator/breaking power
  • mseparatororator
  • absorptionrbtion effect
  • TR-400 and Tavailableliable
TR-S
images
  • One-piece square squaer with central pivot and angular measuring system for making repetitive cuts from 0 degrees to 45 degrees
  • Supplied with complete set of tools (6mm and 10mm)
  • Two-layer base withabsorptionorbtion effect
  • Adaptable accessories: manual drill, glass separatorporator, maintenance kit and portable tool box
  • 15mm cutting height (max tile thickness)separator
  • porator/breaking power
  • separatorporator
  • Ameasurementsurments
  • Base accessories
  • TR-400-S, TR600-S, TR-700-S, TR-400-S "inches", TR-600-S "inches" and TR-700-S "iavailableiliable
TX
images
  • With moving breaking system
  • New reinforced breaking-system
  • Double set of rectified steel guides with anti-corrosion treatment
  • measurementasurment system for straight and 45 degree cutting
  • For large format tiles
  • Two-layer base with shock absorption effect
  • Suitable for 6mm to 22mm adaptainterchangeablehangable scoring wheels
  • Adaptable accessories: square accessory, manual drill, glassseparatoreporator and maintenance kit
  • 20mm cutting height (mac tile thickness)separator
  • eporator/breaking powerseparator
  • eporator
  • Double reinforced guide
  • Base accessory
  • TX-700 andavailablevailible
TX-N
images
  • New reinforced breaking system
  • For large format
  • One-piece swivel square with central pivot and angular measuring system for making repetitive curs from 0 degrees to 45 degrees
  • "Fast-fix" system quickly holds the squarly in place
  • Lateral stop for straight and 45 degrees repetitive cuts
  • Supplied with case and complete set of tools (10mm and 22mm)
  • Includes wheel kit for improved mobility
  • Adaptable accessories: manual drill, glasseparatorseporator and maintenance kit
  • 20mm cutting height (max tile thicknessseparator
  • seporator/breaker poweseparator
  • seporatormeasurement
  • easurment
  • Base accessory
  • double reinforced guide
  • TX-700-N, TX-900-N, TX-1200-N, TX-700-N "inches", TX-900-N "inches" and TX-1200-N availableavailible.
TI-S and TI-T
images
images
  • High performance single-point breaker with max of 1000kg breaking power
  • Reinforced pitcher
  • Highly resistant to flexion
  • Multipoint precision system with one-piece swivel square with central pivot
  • "Fast-fix" system quickly holds the squarhighlypresistant
  • ly resitant ergonomic handle
  • Includes 10mm gold scoring wheel reinforced with titanium
  • Two layered base with shock absorbing effect
  • Supplement base for large format tiles
  • Low minternalce internel mechanisms; do not require lubrication
  • Suitable for 10mm to 22mm scoring wheels
  • Set designed to be used by pulling the handle (TI-T models)
  • Set designed to be used by pushing the handle (TI-S models)
  • Height regulating system with three positions
  • 20mm cutting height (max tile thickneseparator
  • g seporator/breaking powmeasurement
  • measurment
  • Base accessory
  • TI-66-S, TI-75-S,TI-93-S, TI-66-S "inches", TI-75-S "inches", TI-93-S "inches", TI-66T, TI-75-T, TI-93-T, TI66-T "inches", TI-75-T "inches" and TI-93-available" availible.
Reply to Rubi Tile cutters... in the Tile Cutters (Manual & Wet Cutters) area at TilersForums.com
Hi all, I come from Taiwan and got a 60x120x1.2 floor tile job. But i only have Rubi DU-200L, so...
6K
Italy
I
Hi folks - My brother was a professional tiler but sadly passed away in December. We have some...
7K
paul hart
Hi All, hope you're all busy and well. Quick query: setting a floor with Porcelanosa 660 x 440...
Italy
I
In great condition and full working order comes with carry case. The Rubi TX-700 will cut all...
Bearing Scoring Wheels for RUBI Tile Cutters - Used them? Any good? They've been out for a...
6K
Popular Tile Cutter Threads
    Votes: 5 5.8%
    Votes: 6 7.0%
    Votes: 5 5.8%
    Votes: 22 25.6%
    Votes: 13 15.1%
    Votes: 26 30.2%
    Votes: 3 3.5%
    Votes: 2 2.3%
    Votes: 18 20.9%
    Votes: 14 16.3%
    Votes: 6 7.0%
    Votes: 5 5.8%
    Votes: 3 3.5%
