Tiling Tool Suppliers
Discuss Rubi TS75 advice any Rubi experts? in the Tiling Tools area at TilersForums.com.
I have just upgraded to this cutter and am having a bit of a nightmare with some porc wall tiles.
Rubi TS75 MAX Tile Cutter (Grey Base) 18975 - https://www.protilertools.co.uk/product/rubi-ts75-max-tile-cutter--grey-base--18975
I don't know if it's me the tiles or the cutter?
They are not the best tiles and are not flat or of even size, but they are chipping badly when I try and snap the cut, I have wasted about a box of tiles purely down to this now, I bought a Marcrist blade for my wet cutter and it's chewing the edges up badly, looks like a crocodile made the cut, finally started making all my cuts with a Rubi blade in my angle grinder.
Had a problem with heat stress fracturing the tiles so bought a cheap variable speed grinder and it's working pretty well, but dusty and frustrating when you want a simple straight cut!
Blunt Tool
Yes it snaps a chunk off randomly left or right of the cut line at the end where the lever comes up to snap.
Common problem, place tile in nice and square, back score the tile ie pull handle back to around an inch of tile side furthest from measuring bar and score a couple of times then do your normal score. Then pull tile away from measuring bar a small amount before trying to snap
Reply to Rubi TS75 advice any Rubi experts? in the Tiling Tools area at TilersForums.com
Currently using TX700N but obviously now too small for the 1200x600mm I'm increasingly being...
I need a tile cutter gor 600x600 Italian porcelain and am close to pulling the trigger on the...
Tiling Tool Popular Threads
Caerphilly
Business Name
Gas Doctor Services
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
