Discuss Rubi TX 700 problem. in the Australia Tiling Forum area at TilersForums.com.
jollyroger
So I bought a new Rubi TX 700, tried a few cuts at home and thought it was the dog's danglies. However after using it for a day on a job, I have discovered it has a major flaw in the design. When you get to the end of the cut, the cutting wheel slams down on the metal part of the cutter bed. Also when the metal guide is in position the wheel runs right over it. After a few cuts the wheel is blunt. I mean seriously, am I missing something?????
jollyroger
Thanks for the input guys.....Been tiling for years so I know how to use a manual tile cutter. My main point is, when the guide bar is in position, the scoring wheel runs over it, coming into contact with the metal. Good advice about not scoring too hard as I can be very slightly heavy handed. I tried today with a lighter pressure and this has definitely improved my cuts. Think I have been so used to using crap cutters over the years.
Thanks for all the tips but my point about the wheel coming into contact with the metal on the guide bar is correct so will not be using the guide bar in future. This way my cutting wheel will stay sharp for longer period of time.
nybor62
1,083
rotherham
your used to using crap cutters. lol. dont take this the wrong way , but they are crap imho
I
Ian
Its the TX 700 Bri, Dont matter how the scoring wheel is set for height. The metal part of the guide passes through the cut line and sits about 4mm below a 9mm tile so the wheel scores the metal when you get to the end of the cut. Love the cutter but this problem is making me unwell lol.
Seems odd, it's not something I seem to have an issue with, get a video up an see if your technique is the same as mine.
Sounds like ur pushing down, you need too push through . Sounds silly but to me it just like ur being heavy handed. Also, hitting the metal isnt going to blunt the wheel. All wheels - regardless of cutter brand- sound sharp on the first few days of work, this sound dissapates after a few jobs, doesnt mean its blunt tho.
Diggy
blue_max
I am new to tile snappers, having used el cheapo wet cutters in the past. I just got a tx700-N second hand and after my first few cuts, damaged the metal as you describe. I soon learned that it is all about the angle, and not the force. When you first start your cut, try to maintain that angle throughout the stroke. If anything, try to ease up a little towards the very end.
What surprised me was the accuracy of the measuring gauge. I have been used to them being no more than a decoration before, but found it spot on. Now I trust it, which makes life much easier than trying to see a pencil line!
Reply to Rubi TX 700 problem. in the Australia Tiling Forum area at TilersForums.com
Hi everyone, I'm not a regular tiler, just someone who is trying to fix up a few rooms around...
Hello, I hope you can help. I'm get despondent cutting 9mm glazed porcelain tiles, 300 x 900mm...
Hi all, I come from Taiwan and got a 60x120x1.2 floor tile job. But i only have Rubi DU-200L, so...
6K
Italy
I
I'm looking at a nice manual cutter from rubi. I'm set on a rubi as their parts are easy to get...
5K
Hi All, hope you're all busy and well. Quick query: setting a floor with Porcelanosa 660 x 440...
Italy
I
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.3%
    Votes: 17 11.3%
    Votes: 36 24.0%
    Votes: 21 14.0%
    Votes: 18 12.0%
    Votes: 16 10.7%
