Discuss sand cement internal render in the British & UK Tiling Forum area at TilersForums.com.
booner
just hacked off tiles from solid shower wall, set coat has come off with tile( house is only 8 years old), render in behind i thought would be like iron(like external)!! not so, side of paint scraper can rake it back to blockwork with no effort??? is this typical of a shower wall or have plasterers used a very weak mix. will nhbc be interested in this or am i dreamin. any ideas for a remedy b4 retiling:mad2::mad2::mad2::mad2::mad2::mad2::mad2::mad2:
hmmmm, suddenly the original tiles dont seem such an eyesore after all!!!
White Room
Some plasterers have been known to use soft sand (I've seen it) and it dos'nt have the strenght for rendering,internal or external. It could also be a very weak mix, a couple of options for you are, thin down some sbr about 4-1 and soak the sand and I mean soak which will get sucked in and bond the render when dry or rip the whole lot off and dot and dab with plasterboard. You could get hold of the nhbc but the process may be dragged out.
Diamond Pool Finishers
you dont want to use plasterboard in shower/area tile backerboard at least then tank as for wet room :thumbsup::thumbsup:
what did you use before backerboard came along gooner?, I've been tiling for nearly 30 years and not had a problem doing it p/board and tanking. But as you say, it's up to me:thumbsup:
well ive ripped out lots of showers and am forever finding that they have broken down and if pboard is used the gyipsum in it has soaked up the water and gone bad so now i never use it :thumbsup:
Ajax123
1,213
Lincolnshire
I use soft sand in render quite often. You just need a higher cement content. The surface area of the smaller paricles in the soft sand need more cement to bind them. High cement content and small sand particle size leads to fantastic finish - almost as good as finish plaster. I did this as a top coat on my external walls cos I couldn't get a flat enough finish on my scratch coat. Its been there for 10 years or so and is bloomin hard.
I always use a plasticiser in the top coat as well to reduce the water cement ratio. Makes it stronger. Perhaps doesn't meet British standards but it works for me. :thumbsup:
That said if you don't up the cement content or if you put too much water in it or if it dries out too quickly you are right it won't go hard enough. :thumbsdown:
Reply to sand cement internal render in the British & UK Tiling Forum area at TilersForums.com
Afternoon everyone, just after a bit of advice on preparing some walls for ceramic, possibly...
I will have a bath in the corner with a shower over. Most water will go in the bath but the...
6K
Hi, I am replacing a bathroom and after removing the old tiles have found old lime /horsehair...
HI people, I have a 2 storey 3 bed semi 1930s ex council house made from concrete block. with...
9K
TJ Smiler
11K
Rizzle from the Portizzle
    Votes: 14 9.4%
    Votes: 44 29.5%
    Votes: 17 11.4%
    Votes: 35 23.5%
    Votes: 21 14.1%
    Votes: 18 12.1%
    Votes: 16 10.7%
