Discuss Sandy plaster. in the UK Tiling Forum area at TilersForums.com.
Sean Kelly
1,068
Ruislip
I’m working on a bathroom refit (which I have really underpriced!). I’ve taken some tiles off one of the walls and all the plaster (which was not very thick) came away too. I’m now down to the very sandy plaster. My question is can I just prime this wall or will I have to skim it. The walls are pretty straight and level. The attached pic shows the plaster/skimmed plaster & old tile adhesive. Cheers Sean
even if you dot an dab the wall, technically you are supposed to leave it for a week to 10 days before tiling on the dot and dabbed plasterboard
Have you got a link to that AT ? I've never thought about it, and have never had any problems when working on it the next day :oops:
Sean Kelly
1,068
Ruislip
After taking of the top layer of plaster I noticed that the backing plaster was really sandy. I put my finger in a hole in the plaster and gently pulled the backing plaster away. It just fell away in big chunks. The plaster hit the floor and turned back to sand. I will plaster board the wall tomorrow and let it dry over the weekend. Cheers for help. Sean
Sean Kelly
1,068
Ruislip
Cheers Whitebeam. I'll pop over to B&Q and get some plaster board addy. I've never D&D'd before, but I've gone through a few threads and viewed a video of a bloke doing it. Pretty confident about doing it tomorrow. Sean
Reply to Sandy plaster. in the UK Tiling Forum area at TilersForums.com
    • Friendly
Hi, I’ve just crossed over from the plumbers forum for some tiling advice as I’m in the process...
Sean Kelly
Ruislip
Sandy plaster.
    Votes: 5 4.5%
    Votes: 8 7.1%
    Votes: 7 6.3%
    Votes: 32 28.6%
    Votes: 14 12.5%
    Votes: 29 25.9%
    Votes: 3 2.7%
    Votes: 2 1.8%
    Votes: 19 17.0%
    Votes: 18 16.1%
    Votes: 13 11.6%
    Votes: 5 4.5%
    Votes: 3 2.7%
    Votes: 2 1.8%
