Discuss School boy error in the Australia Tiling Forum area at TilersForums.com.
Rich Midge
It was the guys at Instamac that informed me of the crystals, this is going back 14 or 15 years. Though I agree that suction is a major issue I can't see it being the be all and end all. A damp sponge across a skimmed wall would surely prevent the addy from skinning over or drying out too fast but wouldn't increase the overall bond. Somebody somewhere needs to experiment?!
Dash J
I prime because of the high suction from plaster, the cement based adhesive losses the moisture to quick to allow it to cure probably.
Was informed from a bod from Mapei that ettringite is formed when moisture/damp is present.
I think suction is the be all
In a laymans term you are stopping the substrate from being so pourus by priming
Plaster,no primer,suck then pop de bonded
If it was a case of crystals then surely if you primed bonding plaster which is probably one of the most pourus substrates then you could tile it!
Me personally I would never tile bonding plaster if it had umpteen coats of primer
Rich Midge
Agreed bonding plaster will wick away moisture at a rate of knots but is only an undercoat plaster so doesn't have the inherent strength to support tiles regardless of priming or not. No addy manufacturer would guarantee their products straight onto bonding. Like I said earlier, I'm certainly no chemist just expressing an opinion. Personally I live by the prime everything rule.
White Room
Ok, a plasterer puts a finish on dry bonding that suck moisture out so the top coat is worthless, you can prime till the cows come home and it would'nt make a blind bit of difference.
Rich Midge
Completely agree in that scenario priming would be pointless but I don't really get the argument sorry. No plasterer would apply a finish coat to dry bonding. They either do it same day or they prime. If however a plasterer was to do this, the finish coat would be so full of hairline cracks and hollow sounding that no tiler would consider it a suitable surface to tile on regardless of priming or not.
widler
1,328
England
I have never primed a high suction backing plaster in my life, suction is a plasterers friend [emoji41]
Reply to School boy error in the Australia Tiling Forum area at TilersForums.com
Hi Guys i’m going to be tiling over skimmed plaster walls in a kitchen for first time. (first...
School boy error
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
