Discuss Scratches in the UK Tiling Forum area at TilersForums.com.
Topshop
Yes, sanded grout can scratch a polished travertine, limestone, or marble (MLT). More if the grout mix is a bit dry and you apply a lot of pressure while floating the grout in the joint. It is always best to use a non-sanded grout with MLT tiles. That also helps down the road if the tiles need to be ground and re-finished at a later date.
Usually with a honed tile you do not see the scratching very often but it is possible. I have never seen a problem with sanded grout on tumbled MLT but it could also be an issue at restoration time.
Reply to Scratches in the UK Tiling Forum area at TilersForums.com
Hi, I have 45m2 of 1.2 x 1.2 Mirage 9mm floor tiles to lay. Never done this size before. I’m...
Been advised to move this post to the uk forum, didn’t realise it was in the USA forum Would...
Hi I am thinking of training to gain city and guilds on weekends I’m just wondering is there...
Some helpful advice/opinion would be appreciated... Existing tiles on walls, some of the walls...
TF Group Please Join
Scratches
Tags
usa
Tilers Forums on FB
