Aston
you need 60mm screws on 25mm ply. they need to have some decent bite into the joists.
the screws should be corrosion resistant too..
galvanised screws are not seen as a good option anymore due to the fact that the zinc can break down..the whole building industry changed its format on galvanised materials from about 1990.. angle beads, strap hangers, fixing, screws, cavity wall ties all were recomended to be stainless steel or corrosion resistant in exterior or moisture sensitive areas.
