Discuss Scribing bevelled tile for internal corners in the Canada Tile Advice area at TilersForums.com.
Bartlett
Hi, been a while since I posted on here, wonder if you can help? Photos or links to photos would be great.
I have a splashback to do with bevelled tiles, 200x100mm, and this will involve working around several internal corners, both 45 degree and 90 degree (odd shaped kitchen). I understand that there will be a gap if I just make straight cuts and I will need to scribe the tiles to fit, wonder if anyone has any tips or advice on this? Thanks.
Bartlett
Thanks Bri, planning on using trim on the external corners now, so no mitreing needed. Have practised a few cuts for the internal corners and it looks okay, have been using wet cutter on each side (for the bevelled part of the tile) and nipping the bit in between. Fiddly frustrating work, don't know how you guys all do it full-time!
I
Ian
You can still mitre the internal corners, think of it as being a bit like fitting skirting boards, some joiners mitre them some scribe them.
Reply to Scribing bevelled tile for internal corners in the Canada Tile Advice area at TilersForums.com
Hello, I am looking for some advice on how to set out my tiles. I think I have a solution but...
I've seen lots of posts on internal corners in a bathroom but am still confused as to what to do...
Hi, I am in the process of tiling with subways and just wanted some help with corners, if trim...
Hi, first post and a question about Metro tiles. Never used these before but I'm thinking about...
Hi, Im tiling the bottom third of the bathroom wall in a straight herringbone (where the tiles...
8K
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
