Jongy
I've recently fitted an en-suite wetroom and shower. After only a weeks use the slate grout between the slate tiles on the floor started to crack. This has allowed water to penetrate under the slate tiles. The flooring below the slate in tanked. I think there may be a small amount of flexing of the floor and shower tray and this in turn has meant the grout has cracked.
Can anyone suggest a solution? My thoughts are to remove the loose grout and replace it and then seal the whole floor with a flexible epoxy resin, but I'm open to any other suggestion apart from taking up the floor.
Is there any suitable products available?
