self-leveling on impey tanking matt
The impey membrane is the best tanking system IMHO but I'd check the heat output of the underfloor mat as they only recommend 100w. Personally I'd have just used the same flexible adhesive to cover the cables.
Hi, indeed Tilesafe is a little sticky to handle! but you are correct, the new epoxy friendly fleece one sided adhesive membrane alternative is called Impey Waterguard.
May have been helpful if the output of heating mat could be confirmed and which levelling compound Impey would recommend !
Tilesafe works with only single part cement compounds but Waterguard can work with any. For dedicated tech help with Impey products our technical line is: 01460 258 682. They will be able to answer any queries on compunds and underfloor heating outputs.
Thank you
discotiler,
Impey Showers,
discotiler,
Impey Showers,
