Discuss self levelling advise in the British & UK Tiling Forum area at TilersForums.com.
merit
493
hi all
the floor that im working on is level from end to end but hollows out in the middle as much as 8mm,
its timber floor with cement board glued ans screwed,whats the best slc to use to keep the floor height to a minimum and just fill the hollow,ive used weber floor flex in the past but its min of 10mm full floor area if memory serves
is there a min and max on mapei slc ,floor has no deflection and is solid
thanks in advance
charlie1
"WHAT?" i used SBR as a primer for it. :oops:
hi robson, mapei recomend Eco primer, its v expensive too, I was going to try the stuff as heard a lot of good reports about it unrolled I was told the price of the primer. My local tg said most of the guys just use primer g but where would that leave you if something goes wrong? My guess would be that they would blame you for using wrong gear! Having said that, I'm sure you will be fine, I'm just being cautious!
Reply to self levelling advise in the British & UK Tiling Forum area at TilersForums.com
Hi All, I’m ripping out a failed existing tiled floor. Tiles had not been back buttered so...
Hi all. I don’t really post, I get all my info usually from just searching. I have just...
    Votes: 14 9.4%
    Votes: 44 29.5%
    Votes: 17 11.4%
    Votes: 35 23.5%
    Votes: 21 14.1%
    Votes: 18 12.1%
    Votes: 16 10.7%
