Discuss Self Levelling Query. in the America Tile Forum / Advice Board area at TilersForums.com.
Trigger
483
uk
Hi All,
Doing an install at the moment which requires me to self level in two stages. I have put leveller over leveller in the past (priming between coats) and not thought much of it. However today I had a query and decided to call the manufacturers technical team and to my surprise they told me that you shouldn't put a second layer of levelling compound over the first as it won't bond.
Anyone come across this before? Everyday is a school day as they say.
Your thoughts would be appreciated.
Trigger
eddcottee
493
Ipswich
I had a problem recently as Topps had a leveller on sale which I had over ordered on one job, so used on another. Put the leveller in and it didnt quite reach the level I needed. Went to Topps for some more and it was discontinued. So got a bag of another leveller which on the packet highlighted existing self leveller as a suitable substrate, so i used that and the bond seemed fine. Perhaps it depends on the manufacturer mate.
Kevbos
443
London, UK
Please contribute to this thread if you have any new information or can even just reiterate what has been said already. :)
Hi All,
Doing an install at the moment which requires me to self level in two stages. I have put leveller over leveller in the past (priming between coats) and not thought much of it. However today I had a query and decided to call the manufacturers technical team and to my surprise they told me that you shouldn't put a second layer of levelling compound over if the first as it won't bond.
Trigger
They say that because if you go over the first coat there is not much to grip to as the first coat very smooth ! There are different levelling depths specifically to avoid this problem !upto 50mm I think anything above that should really be screeded !!
Reply to Self Levelling Query. in the America Tile Forum / Advice Board area at TilersForums.com
So I may have done an oopsie. We are putting self-levelling compound down over floor where I...
Hi All, I’m ripping out a failed existing tiled floor. Tiles had not been back buttered so...
Will this work? (top to bottom) tiling (one room), 12mm laminate (other room) 19mm T&G chipboard...
Hi. I've just used Mapei Ultimate Leveller 1210 to cover a very irregular concrete floor in our...
USA Tile Forum Popular
America Tile Advice Trending
uk
What member type are you?
  1. Professional Wall and Floor Tiler
    Votes: 5 5.0%
    Votes: 8 8.0%
    Votes: 6 6.0%
    Votes: 25 25.0%
    Votes: 14 14.0%
    Votes: 27 27.0%
    Votes: 3 3.0%
    Votes: 2 2.0%
    Votes: 19 19.0%
    Votes: 18 18.0%
    Votes: 10 10.0%
    Votes: 5 5.0%
    Votes: 3 3.0%
    Votes: 1 1.0%
