Discuss Setting out brick bond from natural centre point causes thin cuts in the Canada Tile Advice area at TilersForums.com.
SlippySlipster
Hi,
I was looking for a bit of advice i have read various posts on here regarding brick bond layouts and several say to avoid having slithers everywhere.
I was wondering what constitutes a slither!!
I have mocked a layout up on my PC (See below) and using a desirable starting point centred to my extractor fan; it would appear that i will be left with two thin cuts into the internal corners.
I have ran my layout around the rest of the room and it seems that the only way i can avoid the thin cuts is to have a strange centre starting point which makes the focal point of the kitchen hob / extractor be not centred in the brick bond.
My tiles are 200 x 100 x 7mm Metro beveled tiles in two colours separated by a 10mm Brushed Steel pencil bar 2mm Grout lines.
Looking at my layout do you think the short 20mm / 10mm cuts are too small and if so how would you correct the issue?
I'm new to tiling and strictly a DIY'er so any advice would be helpful sorry for any stupid questions.
Thanks in advance
Jon
SlippySlipster
Thanks Dave,
May have had a can't see the wood for the trees moment never crossed my mind about changing the gap...
I adjusted my layout to a 3mm gap and now i have a gap to the left of 12mm and on the right 8mm on the full tile row the half tile is spot on now.
How do you get round that do you use the depth of the tile on the other wall and a bit of extra grout?
tommyzooom
1,083
Ireland
Try measuring 50mm from the centre line and start your tile joint from there and see what you get.
This is what I'd reccomend. You will have a 3/4 tile cut and a 1/4 cut on one row, and the same cuts reversed on the next row...It still looks centred when finished.
SlippySlipster
Thanks for your advice,
I have made the alteration to the plan and have the below two layouts although moving to the centre line 50mm has given me the desired 3/4 1/4 bond which is great, because it has moved the centre away from where the focal point of the room is i prefer the way the 3mm with the slight gaps looks.
3/4 1/4 off centre
3mm Grout centered left 12mm gap and right 8mm gap
Can you please advise me of how i can fill the gaps to make them look correct.
Would it be a case of just doing very thin cuts and wrapping the rest of the tile round on to the next wall?
Reply to Setting out brick bond from natural centre point causes thin cuts in the Canada Tile Advice area at TilersForums.com
Hi Tilers, this is my first question on this forum and I've got a few different areas to cover...
Hi everyone, Im after advice tilling my kitchen walls behind hob, sink and under wall cabinets...
Hi, Running a small bathroom job for a customer. Customer really wants to use a particular...
10K
So I have a bathroom to do in 100 x 200 metros. Lucky me. Taps are on long side of bath next to...
J Sid
Hello people. Been up to the eyes with life, but finally managed to progress my (now 6m long!)...
11K
    Votes: 5 4.2%
    Votes: 11 9.2%
    Votes: 7 5.8%
    Votes: 33 27.5%
    Votes: 15 12.5%
    Votes: 31 25.8%
    Votes: 3 2.5%
    Votes: 2 1.7%
    Votes: 19 15.8%
    Votes: 18 15.0%
    Votes: 13 10.8%
    Votes: 6 5.0%
    Votes: 3 2.5%
    Votes: 2 1.7%
