Discuss Setting out for window in the Canada Tile Advice area at TilersForums.com.
Chwrlie
Evening, hope all is well.
Im Looking for a bit of advice regarding setting out on the window wall. Which ever way I play around with it I seem to have a sliver either at the window or both ends. I've attached a photo of the wall and a diagram with the measurements. It would be nice to know how you guys would tackle it. Tiles are 60cm x 20cm ceramics using 2mm spacers. Thanks in advance.
Bill
Might have a solution. If I fit a a dectretive tile at the centre line of window that gives me a 100mm cut either side of the window. Didn't really want to use a decretive tile on that wall but can' really see any other option. View attachment 97590
If you put a chrome box trim either side of the decorative centre tile, then you can cut into the box trim with the two field tiles and have the full tile joint running up the window reveals and create bigger cuts.
Reply to Setting out for window in the Canada Tile Advice area at TilersForums.com
Hello, I am looking for some advice on how to set out my tiles. I think I have a solution but...
Dear Tilers, my husband has done a lot of tiling, but would really like your advice please. He...
Hi there, Im a DIY tiler and am about to half height tile my downstairs toilet with 600x300...
Hi all, Due to money constraints I am having to renovate the bathroom myself. I am trying my...
Hi there, this is my first post and looking for advice on fixing 550x330x8mm ceramic wall tiles...
    Votes: 9 6.2%
    Votes: 13 8.9%
    Votes: 11 7.5%
    Votes: 44 30.1%
    Votes: 17 11.6%
    Votes: 34 23.3%
    Votes: 3 2.1%
    Votes: 20 13.7%
    Votes: 18 12.3%
    Votes: 15 10.3%
    Votes: 7 4.8%
    Votes: 3 2.1%
