setting out time dry lay?
2020Tiling
I seem to be spending a lot of time setting out floors, wondering if theres a quick way ? after prepping i normally dry line a few rows then tweek them to get the best line .. this could lead me to dry lay most of the floor so it doesnt look off angle . how do you lot find the correct line if the rooms not square ?
i look at a room and see which wall will follow your eyeline, i then square everthing off that wall using a long stright edge..
what if theres no walls to come off, i mean if the kitchen has units fitted all round
Put your level against the kitchen unit doors reaching to the floor and pencil mark, I would start from the longest set of units but like everythink play it by your eye, if it don't look right, it aint..
i tend to stand in door ways , and eye up whats going to look the strightest line, if its a long set of kitchen units , take that as being stright, work your tiles out from that line and away you go..
my advice is carry on spending plenty of time setting out, you would be mad to try and rush it ,after a while it becomes less of an issue as experience tells you where the best place to start but for now take your time use your guage stick
spot on :thumbsup:
Drylaying has its place ie a small bathroom floor
Anything else then square off a long straight wall and staff out.
3,4,5 is 3 lines with measurements with a ratio of 3,4,5 creating a right angle triangle. So for example you have a line 30cm long put a 40 cm piece of string at one end and strike an arc. Then get a 50cm piece of string with a pencil say and strike an arc, where the two arcs intersect above the original 30cm line will give you a perfect right angle. To make the triangle bigger you can have a line say 60cm;80cm;100cm, as long as the ratio is 3,4,5 you will create a perfect right angle, whatever the measurement unit is.
Pythagoras, square on the hypotenuse 3/4/5 basic tiling or building formula. Before steel squares, or lasers:smilewinkgrin: The square of the hypotenuse, is equal to the sum of the squares of the other two sides, simples:thumbsup:
...or 5,12, 13,,,,,useful on long corridors. But you still have to decide which wall you're starting from, I quite often dry lay first, not completely on a big floor but most times to get the initial lay-out.
I love a simples answer - actually found a use for my o level maths from 1974!! The best tiling advice I have picked up tends to be the basics like this that we should all know but dont care to remember.
Outside walls should be square, so I tend to go for that, but still use a staff. I do dry lay small areas too. We all have our own ways, as long as the finished job is good, there is no right or wrong way. Whatever works for us is good.:thumbsup:
lol i am familiar with the 345 square on the hypotenuse just don't know how it will help the op set out his floors ????????*
I still rely on the old Lancashire method Dean, rac o' theye, if it looks right, it probably is.:lol::lol:
3,4,5? on your tape measure 3ft up your chalk line from centre of the room then 4ft to the right or left of line. Then from the 3ft mark measure 5ft to the 4ft mark, then at the point these two meet put a mark through it to form an x. now string you line through your centre mark through your 345 mark from wall to wall. now you will have 4 right angles a square floor. simples
I've been doing this for 22year and i still lay tiles out. You just get quicker at it thats all. LOL
lol*
so can you enlighten me then how dose it help the op set his floor out ?????????????????????????
i have not drifted from original question. i am looking to find out how 345 helps set out a room that is out of square faster than using a square.*
UK Tiling Forum; UK
2020Tiling,
widler,
2020Tiling,
widler,
