jonny
Hi guys
I have been reading on the forums and I was wondering if anyone could give me some advice?
Renovating a bathroom and need to tile an external wall, but the problem is I can tell that as soon as I remove the old tiles the plaster is going to come off the wall. So I have decided to take off the old plaster down to the bricks and dot dab plaster board on to bricks and tile over after tanking.
Is the recomended thing to do does anyone know? If so do i need to screw through the dried dot dab and if so with which fixings so that I can tile over them?
By the way I am tiling with some thin porcelain tiles which are 300mm x 600mm x 4.5mm thick. Also there will be a bath and shower on the plaster boarded wall obviously with the correct fixings and in to the brick, the rest of the bathroom walls are plasterboard and have ceramic tiles but are very solid and will probably pull off plasterboard if removed. Would you recommend tiling over these with a flexible powdered adhesive?
Any advice would be greatly appreciated.
