Guest viewing is limited
Discuss Should I use Epoxy Grout or Not? in the Tile Adhesive and Grout Advice area at TilersForums.com.
A standard flexible grout should be more than sufficient for a domestic bathroom. They all contain fancy "anti fungal" "anti mould" chemicals now to make cleaning easier. As with everything good ventilation is key! Most of my tilers cry whenever you mention the word "epoxy". Good Luck!
tilerdave
We used it for a customer as they wanted glitter grout, keraproxy stuff, 30m2 of floor, we won't use it again, you have to buy the cleaner for it too to get excess up, we used a credit card to scrape up the excess then spray on cleaner, with the glitter and the resin sticking to everything you find you have to buy all new stuff that it's been in contact with as your next customer wouldn't appreciate glitter in any of their bathroom/kitchen. Just my opinion
Dan
Admin
Staff member
5,094
1,323
Staffordshire, UK
That's fairly standard I think with all epoxy unless it has change since I last used it. You're meant to use a stiff epoxy float, then emulsifying pads (white so colour doesn't seep) to break it down then a sponge. The pads and sponges go in the bin they can't be rescued.
You can use a couple to stop drills and things sliding around shelving in the van or something. That's about it lol
Reply to Should I use Epoxy Grout or Not? in the Tile Adhesive and Grout Advice area at TilersForums.com
Hello, I did some reading here and there, but the opinions seem to diverge at some point and I...
A question about mitering and matching epoxy colour I'll be working with some pinkish matt...
Hi any info on get rid of epoxy grout haze on natural stone would be much appreciated. I’ve used...
Hello everyone, I have redone the tiles (porcelain ones) in the kitchen. The grout used, BAL...
Tile Adhesive Trending Topics
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
