Discuss New grout much lighter than sample, what options do I have? in the Tile Adhesive / Grout Advice area at TilersForums.com.
Lucy28
Points
11
London, UK
Hello everyone,
I have redone the tiles (porcelain ones) in the kitchen. The grout used, BAL Micromax3 Eco, has turned out to be quite lighter than the sample in store, creating an unwanted effect.
Tiler say there is nothing I can do now, besides removing the grout (risking to damage the tiles). He advised against dye them or using a grout pen.
I just would like a second opinion - is there really no good options out there?
I feel very stupid as I should have had the tiler produce a sample to see the final result rather than just relying on the store sample. Anyway, damage is done...
Thank you so much in advance,
Lucy
Tiberiu
Points
113
Suffolk
The only way to correct the wrong colour is to remove the old grout. You can achieve this using a multitool with a diamond blade
Lucy28
Points
11
London, UK
I have been told by my tiler that, because gap is 2mm, there is a good chance to ruin the tiles by using a multitool. How do you feel about grout colourants (the ones I know are Mapei Fuga Fresca, Universal Grout Rescue) ? Area that needs retouching is not very big, 1.50x1.80m , tiles 20x20cm
Lucy28
Points
11
London, UK
I also read that Grout enhancer sealer may be an option? It seems this product could darken the grout giving a permanent "wet effect". Incidentally, when my grout is wet, it is are exactly the colour I would love it to be...
Kastar UK
Points
163
Leigh GtrManchestet
Only way is a hand held grit grout rake and then still need to be careful , would need to remove a few mm depth,
can use tapes , masking etc to protect tiles
Wouldnt go near it with a mutli tool room full of damaged tiles
Reply to New grout much lighter than sample, what options do I have? in the Tile Adhesive / Grout Advice area at TilersForums.com
