Guest viewing is limited
Discuss Shower Tile in the UK Tiling Forum area at TilersForums.com.
Deleted member 1779
You need diamond core tile drills. We produce a commercial grade strength
under the brand name PORSADRILL
Our diamond cores will cut holes into the toughest porcelain C5 Grade tiles
Plus other material like granite, marble, glass, ceramics, travertine and other stone.
Our small cores come in a pack of four.
When installing a shower screen (Example below)
We insert the guide rail in silver first
To diamond drill the tile with PORSADRILL core hole saws you need the yellow guide plate.
This prevents the core from slipping on the tile.
Mark out your holes with either pencil or masking tape and pen.
Above is the result when you start to drill the tile.
Once started the yellow plate can come off the wall tile.
The diamond drill bit will centre itself from now on.
To stop the hole saw from over heating use water.
We control the delivery of water to a diamond core on the wall tile
by holding the water sponge underneath the core. It will deliver the
water to the drill bit as you bore the hole into the porcelain tiles.
[yt]W2CXLSjpVhU[/yt]
If you need sizes for the service pipes too then we have a great selling product called the
BATHROOM FITTERS KIT. See video above
Reply to Shower Tile in the UK Tiling Forum area at TilersForums.com
Is there anyway of getting a good fixing, where the upright of the shower enclosure meets the...
Shower Tile
