Shower tray movement - tiles will be ok???
Have just noticed movement in the steel shower tray at the corner edge. I have tiled the adjoining floor tiles so now am unable to remove the tray from its position as it is butt up against the wall - see photo
options - tile onto the tray whilst in its lower position so it can’t rise when stood on? This would require adhesive rather than silicon to prevent movement
remove ceiling from below the shower room (first floor) and secure the tray to remove any movement.
Neither option sounds great!
Option 3: Remove the floor tiles butted up to the tray, remove tray, find out why it's moving, fix and refit.
Easier and less making good than taking down the ceiling below the tray!
Don't tile down to it as is and hope that a wall tile will stop the tray moving, it won't.
Balls ache to have to break out a couple of tiles you've just laid, but better that you discovered the problem now and not when the job was finished and the ceiling downstairs started getting wet...
[automerge]1586087389[/automerge]
Thank you. Mmm perhaps the best option so far. I’ve been re thinking and the option underneath is out anyway as I lay the tray onto 12mm of cement board so access is out from below. I am wondering if I create some weight - similar to filling a bath with water prior to sealing - and I place a further skin of tile backing board - STS - onto the top of the tray thereby creating a further skin to the wall, floor to ceiling. I would then tile as normal . This will have the effect of securing the tray into position. The movement is 2-3 mm at present. Thoughts ?
I hate the thought of angle grinding out the three tiles against the tray
If taking the tray up isn’t an option then I would put some weight in the tray to loose the drop, then tile as normal making sure you leave a 2-3mm gap under the tiles to tray.
Leave the the weight in until everything has been grouted and siliconed and has dried sufficiently.
I can’t see it being a problem later if done that way.
[automerge]1586090611[/automerge]
What did you use to stick the tray to the floor, just realised it’s a steel tray.
Brill. I took up another tile today as it was warped - on the edge of the new tiles it was a mare cleaning up the Ditra beneath which I didn’t want to rip up as well.
Tanking and Wetrooms
Jcshutts,
Jcshutts,
Jcshutts,
Jcshutts,
