Guest viewing is limited
Discuss shower tray trouble in the UK Tiling Forum area at TilersForums.com.
Richard Edwards
Spot on Scottley - Remove plasterboard and use 12mm Lux or similar, Tape the corners - and seal with pucker Lux sealing compound and away to go.
If this is no good - dimension wise, then remove old plasterboard and chuck it. Fit tray and then fit new plasterboard, leave a 2/3 gap under it - enough to get Ditra / Imperband in well behind the tray and then apply tanking membrane - ie Ditra / Imperband to the new plasterboard and slot down the sides of the tray and secure. Silicone the tray to the outerface of the membrane and start the tiling the next day.
PS lay the sheet membrane horizontally with an overlap of about 50/80mm and seal overlap with cementous sealing compound.
That will work
BigAl
Thanks for replies - I have the Mapei showerproofing kit because I've built some niches - could I use that on the plasterboard, silicone the plasterboard to the tray, then tile? Like so....
Richard Edwards
You could, as long as the tanking layer (not sure about the Mapei product as not one I use or familar with) is properly sealed and tanked at the bottom corner and under the ' tanked plasterboard ' edge.
Its a bit like asking an Irishman -
[Q] Can you tell me the way to Galway ?
[A] Yes I could.
[Q] Well then - which way Paddy ?
[A] If I was going to Galway, I would not start from here. !
Most of us on here would not start from here - we would use 12mm cementous board - several brands or a flexible sheet PE / cotton flock membrane - several brands
See you in Dublin or was it Galway you going to.?
BigAl
[A] Yes I could.
Ay, but if I start from here it's cheaper, I already have a ticket and I'll still get there all the same.
Reply to shower tray trouble in the UK Tiling Forum area at TilersForums.com
Hello, I'm having trouble finding any decent stockists locally. I've got a Topps very near, plus...
  • Sticky
Hi. Just thinking about shower trays. Do shower trays with an integrated upstand require sealing...
shower tray trouble
