Discuss Silicon instead of Grout! in the UK Tiling Forum area at TilersForums.com.
Clare
Hello
I am really upset and need some expert advice.
I have had some tiles put on my en-suite floor and walls this week. They are black porcelain. The tiler recommended silver/grey grout and we went ahead with it.
He said yesterday he had finished and I was shocked when i saw what he had done...he has grouted using the silver/grey, but then in the 4 corners of the room where the walls meet, from floor to ceiling he has used shiny white Silicon! Oh my word, what a contrast to the rest of it...I may as well have had flashing lights! he has tried to tell me this is normal procedure, but I have had many bathrooms fitted over the years and havent seen this yet! can someone advise me if this is right? I am sure it is not, it looks dreadful!
please help.
:sad_smile:
F
Fekin
Walls move, so if grouted the grout may crack over time, where as Silicon is flexible and will move with the walls without cracking.
A lot of tilers always do the wall joints in Silicon as it makes them a flexi joint, but I know colour can sometimes be an issue, so it depends on what colour Silicon you can get.
I must say I have only ever seen whitre and ivory Silicon, but Im sure if searched for you may fine a company that makes an assortment of Silicon colours.
DHTiling
Its not a case of it may move ... it will with moisture and thermal changes in the room.....if the siliconing is done neatly then you can hardly tell..sounds like this Silicon joint you have must be on the thick side is it....dave...
p.s...you can get black Silicon as well as many other colours ...
F
Fekin
Using Silicon is really the norm, he just needs to colour match it to the tiles better.
I would guess since the tiles are black porcelain and silver-grey grout, then a white Silicon line even on the thin side would still stand out, but if there are a wide selection of Silicon colours then there must be one to match better.
Reply to Silicon instead of Grout! in the UK Tiling Forum area at TilersForums.com
Hi, Need to choose a grout for the above. For the black floor tiles 300x600 am thinking either...
I recently got several loose/hollow tiles rebonded on my bathroom floor. Having left with...
    Votes: 5 5.0%
    Votes: 8 8.0%
    Votes: 6 6.0%
    Votes: 25 25.0%
    Votes: 14 14.0%
    Votes: 27 27.0%
    Votes: 3 3.0%
    Votes: 2 2.0%
    Votes: 19 19.0%
    Votes: 18 18.0%
    Votes: 10 10.0%
    Votes: 5 5.0%
    Votes: 3 3.0%
    Votes: 1 1.0%
