Discuss Silicon internal corners... in the British & UK Tiling Forum area at TilersForums.com.
doug boardley
i'm trying to understand your post, when tiling the first wall into the corner, leave a gap of 2/3 mm for expansion. when tiling the second wall into the same corner leave a gap of 2mm between the 2 tiles again for expansion. rake out any grout from the expansion joint prior to siliconing
lol, thought it just me
davemul
Phew! I'm glad I looked in to this thread! :detective:
So when I start tiling (I stress WHEN, this bathroom rebuilding lark is tough work!) on each single vertical corner line (4 of them as it is a simple ish 4 walled room), i'll leave a 3mm gap and JUST use silicon.
What is the best silicon on the market at present for this job?
thanks guys!
Oh I kinda understand what RichieHall means... say you have a tile of 9mm thick and lay it just 3mm off from the wall. When you lay tiles on the other wall they will overlap slightly. You will still have a 3mm gap but overlapping edges. So you need to leave a gap of the tile thickness first plus the 3mm
hang on, ill do a dodgy MS paint picture :idea3:..... am I being a tit / teaching you to suck eggs? sorry of so, its not intentional just making sure i've got it right as if i never read this thread, I would have grouted! :44::dunce:
Rich
I see what he means, but if a tile is, say, 10mm, you would leave that tile 2-3mm from the wall and then the tile that butts into that one will be left 2-3mm away from that one not the thickness of a tile plus 2-3mm. Basically, you want a 2-3mm gap between tile and anything else.
Here are some pics of the Silicon in my mothers bathroom, the joint between the bath and the tiles was grouted and then siliconed over the top. You can see in the pics that the grout has cracked and lifted the Silicon away with it, leaving a gap for water to get through.
davemul
Not 100% sure on floor tiles yet mate.
First it was going to be a dark floor light wall... but bathroom is small with no natural light so now going all light.
Wall tiles are large oblong. Im not sure whether to go same size for the floor or square!? ive been uming and ahhing for weeks on this.
what do you reckon out of curiosity?
Rich
I dont like to get involved with what looks the best as everybody has different taste. Just keep in mind that if your wall tiles are say 300x600mm and you go for 300x300 floor tiles, then the tiling will look much nicer if you can follow the joints along the floor and up the walls. the same goes if you go for 300x600mm on both walls and floor (brick bond or not). You are going to want to take your time when planning out the lay out of this room, its worth it as the planning can make the difference between a good and a bad tiling job.
Reply to Silicon internal corners... in the British & UK Tiling Forum area at TilersForums.com
Hi all, As per the title, my tiler has grouted the internal corners of our new shower enclosure...
My tiler has made a huge mistake (which he excuses as being unlucky with measurements). There is...
    Votes: 14 9.4%
    Votes: 44 29.5%
    Votes: 17 11.4%
    Votes: 35 23.5%
    Votes: 21 14.1%
    Votes: 18 12.1%
    Votes: 16 10.7%
