Discuss Silicon Joint Headache in the British & UK Tiling Forum area at TilersForums.com.
Blue Smithy
Hi All,
Thanks to the info on this site I have managed to tile my bathroom and it looks great - porcelain , finished matt glaze (no sealing required). I also installed a separate shower (tray and screen) and followed the advice of leaving a 3-5mm gap between the tiles and the tray. Also, I installed the tray first and tiled from that, so there is a good 20mm of tile and adhesive overhanging the tray edge.
I then filled the line all around with Silicon, first getting it into the gap then finishing off the external bead. Heaven for a few weeks until I started noticing some wetness at the end of the shower tray. I ended up cutting out the Silicon to investigate and the gap was damp, so there must have been a leak somewhere along the seal.
Im confident that water is not comming from anywhere else but this seal. I raked and dried out the gap (completely), cleaned with meths and reapplied the Silicon..... a few weeks later same problem.
Anybody any ideas? I can only think that I am not cleaning the tiles and tray adequately before siliconing so the bond is weak or that there is movement and the seal is being weakened. I got the missus to have a dry shower while I watched but there was no movement at all with the tray.
Any help and tips would be much appreciated before I take on the sole destroying task of removing and re-applying AGAIN!!!
Cheers
BS
Blue Smithy
Cheers for the replies both,
I siliconed the internal corner, and after inspection its looks to have bonded really well..... thats what led me to think its the shower tray bond.
I'll have a look tonight for any cracks in the grout though... thanks.
Im pretty sure the pipework is ok too. Its installed in a stud wall so I left the plasterboard off for ages to keep any eye on it.... no leaks!
Big-Smudge
I which order did you Silicon i.e did you Silicon the vertical corner first then wait for that to go off and then Silicon around the shower tray.
If so this could be the problem, new Silicon will not bond to old Silicon even if there's only a 3 hour delay between doing the vertical and horizontal. So where the 3 beads of Silicon join right in the corner, there will be a join between the first vertical bead and the shower tray bead. Water will soon find its way in, where you have a 3 way corner this needs to be formed out of one continuous piece of Silicon i.e it all needs filling with Silicon and all smoothed and formed at the same time.
Cheers
Andy
Big-Smudge
You know what Andy, that makes perfect sense to me and is the most plausable problem Ive heard.
I did do the vertical first, and then the horizontals maybe a day later....
At least my Silicon removal skills are getting better!!!
If you want to take the pain away try these items :lol:
Cheers
Andy:thumbsup:
sstilingservice
Hi Blue Smithy
Am I right in thinking that you didn't use a tanking kit ? Coss this could have saved you all this greif !!! for a small amount of outlay. I always strongly recommend them when doing showers because they are a nightmare if you get a leak. If I was you I would remove all Silicon from all corners allow then don't use the shower for a while then reseal and cross your fingers.
You could try a Silicon eater to remove Silicon residue.
Reply to Silicon Joint Headache in the British & UK Tiling Forum area at TilersForums.com
Hello All, I have a shower tray installed and it is sitting away from the wall. I am going to...
Hello, I am about to waterproof an existing shower after taking out all of the old tiles and old...
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.1%
    Votes: 18 11.9%
    Votes: 36 23.8%
    Votes: 21 13.9%
    Votes: 18 11.9%
    Votes: 16 10.6%
    Votes: 7 4.6%
    Votes: 4 2.6%
