Discuss Silicon Outside? in the British & UK Tiling Forum area at TilersForums.com.
Benny Tiler
Hi
I had a phone call from someone I know who has a villa in Portugal. He has a tiled verenda with tiled skirting. He's noticed some water damage on a wall in the room below the veranda.
When he's looked at the veranda where the tiles meet the tiled skirting at the edge it's grouted, which has cracked and started to get washed away, so this is probably where the leak is.
If I was tiling a floor inside I would Silicon where the edge meets the wall, I guess this is the case outside? Having checked the BAL website their Silicon is suitable for exterior.
I just want to check the solution would be to scrape the cracked grout out and Silicon seal? Is there a better Silicon to use outdoors?
Should I arrange a free of charge / expenses only visit to investigate? :8::lol:
Ben
Most roof terraces in Spain and Portugal, especialy on houses sold to foreigners as holiday homes are badly constructed, not tanked and eventualy leak the reasons given by the builders is that it dosent rain enough to warrent doing it properly well with the worst and wettest Winter in living memory still ongoing in Spain and Portugal they are wishing they done it properly now.You will probably find that the skirting tiles are sat straight on the floor tiles, normal practice here, so the grout has just been wiped over which eventualy comes away and allows the water in. If this is the case take them of and replace with new but sitting them on a 2 or 3 mm spacer so you can get a good bead of sillicone in it, failing that rip it up and do the job properly.
Lucius
Reply to Silicon Outside? in the British & UK Tiling Forum area at TilersForums.com
Been advised to move this post to the uk forum, didn’t realise it was in the USA forum Would...
Hi any advice on what would go with what. I've layed off white tiles on floor with grey...
Silicon Outside?
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.1%
    Votes: 18 11.9%
    Votes: 36 23.8%
    Votes: 21 13.9%
    Votes: 18 11.9%
    Votes: 16 10.6%
    Votes: 7 4.6%
    Votes: 4 2.6%
