Guest viewing limit reached
Silicon over grout
Jonjames
Hi All
Is it ok to put Silicon over grout? Got a large gap - 1cm - between the bath and the tiles and so I filled some of it with grout - planning now on finishing over this with the Silicon - just wanted to know if anyone else has had thios experience - i can probably carve out most of the grout if I absolutely have to
cheers
Jon
Hi All
cheers
Jon
Is the bath 10mm out from the wall or are the tiles coming down the wall 10mm short of the bath
The tiles come down the wall 10mm short of the bath - they are 450 by 300 and they stick out about 8mm also so I've put in some grout to fill most of the gap but left enough space to put Silicon on top to seal it -
Cheers
Jon
Silicon won't stick to grout over the long run.
If you can you should Silicon first allow it to cure then grout.
Cheers
Jon
Did you not tile UP from the bath?
could you not remove the course of tiles round the bath, get some bath to tile trim which may gain your ten mm and nip some off the tile if needed as you replace them? silcone n grout will look atrosish if im honest. Or can you not source some type of ceramic quadrant style border like gets used on victorian?
You can get a bath seal that will cover that gap.....tele-seal from screwfix.....will look better than a 10mm grout/Silicon gap..
I agree with dave, grout or silicon should only be used for 5 - 6mm gaps at the very most otherwise the grout will crack and the silicon just pull over time. Also not a good idea to silicon over grout.
any chance the bath legs will wind up a bit? altho' it's probably been siliconed in!
Thanks for all the replies - the bath is slightly concave so at the head and foot the tiles are about 3mm above and in the middle about 10mm. The grout is in the gap so it will be behind the Silicon. The Silicon will adhere to the tile and the bath but have the grout behind it - and that's why I made this post because I'd heard ("Also not a good idea to silicon over grout" (Rob)) that you shouldn't put Silicon over grout and I'm curious to know why? - do they react togther in some way? In this case the silcone will be in contact with the grout behind it but the grout won't be visible and the Silicon won't be sticking to it. I could have used some kind of cheap filler but I thought grout would be fine.
Thanks for the tip on the seal product - would be a good idea but it's a small bath and it slopes away from the wall immediately
Cheers
Jon
Silicon over grout
Jonjames,
alib103,
Jonjames,
alib103,
