Discuss slate bathroom floor - help! in the Bathroom Tiling Advice area at TilersForums.com.
doris4646
Apologies if this question has been asked before...
We have just had a riven slate floor laid in the bathroom. This was then cleaned using Qep Heavy Duty Tile Cleaner to remove all the marks and grout.
It has now left the tiles white and cloudy and stained, some almost bleached and generally looking a complete mess.
We have washed and washed and scrubbed them - even using a carpet cleaner but nothing changes the appearance.
Is there anything we can do to remove this or cover it up?
When they are wet they look fantastic but as soon as they dry they look awful again.
I really don't want to remove them if possible as this will mean taking out the bath etc etc but its looking like we may have no choice.
Any help/advice gratefully received.
Perry
You can't see it at all if the tiles are wet. It's not crystals, its looks just like limescale, sort of dry & powdery, except you can't rub it off.
i think the moisture could be getting into the side of the slate through the joints and not being able to get out again as it looks like a surface sealer its getting trapped
DHTiling
It could be effloresence...i would try LTP grout stain remover as this removes effloresence...follow the directions on the bottle and then once it dries ,if you have the same effect then we can try a couple more options.
If it was topical sealer issues then the grimex would have removed the whitening if you followed the directions for mixing and usage.
Perry
Thanks very much both, I'll give it a go and let you know how it goes.
Pjc if I'm still having trouble I might give you a shout as I'm in Bourne End!
Kim
ok give me a pm with your phone number as in bucks i hope not herts
Reply to slate bathroom floor - help! in the Bathroom Tiling Advice area at TilersForums.com
We had a wet room fitted by a large company. We have issues with a few large steps where the...
Hi, We washed our Indian slate floor with stone floor cleaner and whilst it has cleaned them...
Unsolved
    Votes: 9 5.5%
    Votes: 17 10.3%
    Votes: 12 7.3%
    Votes: 46 27.9%
    Votes: 21 12.7%
    Votes: 39 23.6%
    Votes: 4 2.4%
    Votes: 4 2.4%
    Votes: 22 13.3%
    Votes: 19 11.5%
    Votes: 17 10.3%
    Votes: 8 4.8%
    Votes: 5 3.0%
