Daz
I've been asked by a developer that I do some work for to do 18m2 large format slate onto a kitchen floor.
The floor is part cement screed and part floorboards. The developer is talking about replacing the floorboards, as they are rotten with 18mm ply. This will, apparently, level the floor. He, also, wants electric UFH (matting) laid.
My understanding is that isolation membranes can't be used with 'lectric ufh :mad2:, so I am trying to work out the alternatives so that I can provide my quotation.
Option 1 - Replace floorboards with 12mm ply and then glue & screw 6mm cement boards leaving 10mm between screed to fill with silicon, i.e. expansion gap. Lay ufh, then self level prior to sticking the slate.
Option 2 - Replace floorboards with Wedi, lay ufh, self level then stick.
Option 3 - Self level screed and ply, lay ufh, self level then stick.
Option 4 - I'll leave this for you guys to recommend alternatives??
Am I on the right track? Can anyone point me in the right direction, please?
Thanks in advance.
Thanks in advance.
