Discuss slate problems (again) in the British & UK Tiling Forum area at TilersForums.com.
tactile
ok, i know this is a frequently asked question. ive tiled some slate that has been sealed twice. just grouted it today with BAL superflex grout and its as if the grit in the grout has scratched the surface of the sealer!
looks as if ive rubbed over the tile with a light sandpaper almost!
also ive still got a chalky residue left on the tiles, its not bad but just wondered if there were any tips and would resealing the tiles get rid of the abrasion marks? the tiles look fine when wet. its just when it dries out!
Time's Ran Out
Hi.
What make of seal did you use as the 'stone seal' I prefer is clear and almost invisible when dry.Some impregnating sealers tend to leave a sheen on the tiles and if the grout has lightly scratched the surface it may have just been this left on the surface.I wouldn't put any more seal onto the tiles until your happy with the surface and certainly use a mild cement cleaner to remove the chalky residue first. I'am in Tynemouth tomorrow (on a slate floor) if I can be of assisstance. :thumbsup:
tactile
the sealer was FILA slate impregnator sealer. it was left overnight to dry.
it's only a small floor and the customer seems ok with the result so far, but i know its not as good as past slate floors i've done! i usually stick with a charcole grout as the residue doesnt show as much as grey!
i certainly wont seal the slate again until i'm happy with the cleanliness of the tiles, but any tips on what to clean them with without making matters worse would be appreciated!
Reply to slate problems (again) in the British & UK Tiling Forum area at TilersForums.com
  • Sticky
5K
Matthew7
Our house has raised planters built from concrete block, rendered, painted white and capped with...
Hi all, I live in Cyprus. Bought a new build top floor flat a couple of years ago with a roof...
Hi guys, Please help me. Really having a nightmare here. Just moved into a new house and the...
5K
    Votes: 9 5.8%
    Votes: 15 9.6%
    Votes: 11 7.1%
    Votes: 46 29.5%
    Votes: 19 12.2%
    Votes: 37 23.7%
    Votes: 4 2.6%
    Votes: 21 13.5%
    Votes: 18 11.5%
    Votes: 17 10.9%
    Votes: 7 4.5%
    Votes: 3 1.9%
    Votes: 4 2.6%
